built in tankHi. Are you running from a remote fuel tank or an inbuilt to the boat tank ?
I will try open cap. Yesterday replaced fuel bulb as existing seemed plugged some. I removed the fuel cap to add Sea Foam and there was pressure in the tank. Is this normal?Is the vent system clear? Try running the motor with the gas cap open. Does it run if you squeeze the primer bulb?
After Sea Foam and new bulb runs better but still sputters when reducing throttle.I will try open cap. Yesterday replaced fuel bulb as existing seemed plugged some. I removed the fuel cap to add Sea Foam and there was pressure in the tank. Is this normal?
Is the fuel priming bulb the right way around ? Easy to get that going the wrong direction occasionalyI will try open cap. Yesterday replaced fuel bulb as existing seemed plugged some. I removed the fuel cap to add Sea Foam and there was pressure in the tank. Is this normal?
Excellent. Be almost sure it was the fuel bulb perhaps. Great resultHappy to report that either fuel bulb/hose or sea foam has it running great
