I am new to Force motors and last year I bought a boat with 125 Force by Chrysler. Seller said both were 1986 year. I spent the year working on the hull and used the boat this fall it ran out okb but I reckoned the motor need some TLC. As it turns out the lower unit is a 120 hp Chrysler unit serial number 1209HG5629 also by Chrysler, but is an earlier year. The seller did later admit he had the lower unit rebuilt just before selling it to me. So yesterday I decided to pull the prop to check out the seals and reapply some anti-seize. First thing I noticed is the prop is slightly loose. Then I noticed the only thing holding the prop on is a stainless lock nut. One of those nylon insert type jobbies. Now an inch or so behind this is a hole with a lone cotter key through the shaft. It holds nothing. Also noticed rust comming from behind the nut. Turns out a stack of plain carbon steel washers where used to provide a spacer over the end of the spiled shaft and allow for tightening of the nut. Except the nut bore against the shoulder of the spline when tightened, hence the looseness. So it appears like I need the proper attaching hardware. I am familiar with Merc with thrust washer having interal splines and external locking tabs. using the spider type locking washer to hold the nut from working loose. I am assuming that Force has a similiar set up. So now I need to know what year lower unit it is and then locate the right parts. Thanks for any help Fishboy
