Re: Force 50 Lower unit
Driftwood ,If you wanted to try to test for leak location yourself you could rig up a threaded fitting or schrader boot that you can attach a bicycle pump to.Drain lower unit oil and attach fitting to either drain hole or vent hole leaving the other tightened in place.Fitting needs to be water tight.Submerse lower unit in container of water deep enough to cover waterpump discharge ports.Inject air with bicycle pump up to 10psi and observe if air escapes from propshaft seal area ,vent or drain screw, or water discharge ports.If air comes from discharge ports leak is likely driveshaft seal or shiftrod seal. <br />A pump equipped with guage will allow you to determine when 10psi or approximate is reached.<br /> If you are getting water in lower unit it could also be coming in from something as simple as drain and vent screw seals as Spinner bait nut mentioned.You can replace these very cheaply.<br /> Man, I think I ate too much turkey.I feel like I'm fixing to blow a seal.
