fisheymikey
- Jul 30, 2012
- 450
well I here we go again...
this is the symptom: it gargles at 3500 rpms then clears up and then sometimes runs rough at 4300
I have done the following:
installed new see threw filter no bubbles clear
installed fuel pump diaphragm
changed all connection
changed fuel lines
primer bulb
timing at 28 degree at static
i have linked and sinked
any ideas anyone. i know it something stupid. the engine did run previously at 4900 rpms and all of a sudden it stopped.
because i don't have the time to do everything here is my suspicions at least someone to tell me were should i looks first.:
redo the carbs i did play with the floats and bent them back to spec did not replace the needles with polimer tip did looked in good shape
spark plug boot a small crack but it still making contact.
or maybe cdi or coils.
changed fuel lines
primer bulb
