Force 120 HP Thermostat
Purchased a used boat with force 120s. Have put about 15 hours on them both run fine 42 MPH WOT on 23' walkaround.
Started to change thermostats and there were none. Should I go ahead and put new thermostats in or can engine be run without them.
Thanks for any help
roscoe
Re: Force 120 HP Thermostat
Unless you are running in 100* water, you should replace them.
Be prepared for sticker shock.
