vissertrades
- Aug 16, 2003
- 79
Hi all,<br /><br />I've noticed some play in my '95 50hp Johnsons flywheel/top bearing. There is no play side to side but some fore and aft. It has been there since I bought the engine last spring. I did some online searching and came up with loose top bearing bolts as a possible cause, I found OMC even had a TSB on the subject for some models. So, I was able to tighten those two bolt with a small 5" long 1/4" ratchet. I tightened them only to the point I felt the 1/4" ratchet could handle. I think the torque is fairly close to spec 20ftlbs as It felt like 40-50lbs on that small ratchet. I don't have a small enough torque wrench to get at those bolts. Play went away! Flywheel turns fine. Should I check the other bolts? Should I pull the top two bolts and use loctite? Should I worry that the bolt torque may not be perfect?<br /><br />Thanks!
