And one more of the fill to the left and overflow to the right.
Hope this helps
Ok, here is my setup on my 2006 Q6 S/F
Livewell with drain plug installed
Plumbing for fill and overflow. Pump is towards the bottom
Shows the drains
The screen intake and the drain to the right and higher
The livewell switch. Manual will keep filling, and auto fills for a few minutes and the stops and then fills again etc. to keep the water fresh and will drain out the overflow.
I have an 08 q6 and this live well confuses me every time I'm out. How do you fill your well? I usually turn on manual and it will spit like two tablespoons of water into the well then you just hear the pump running. I can leave it for five to ten minutes and nothing, just hear the pump running. I switch it back and forth to auto then manual and eventually it will fill like nothing was ever wrong. Is mine broken or am I just doing it wrong? Thanks
Your's looks like mine. Have any idea what the 'lock'/unlock switch on the top of the pump does?
The lock/unlock is so that you can take the mechanics part of the pump out and replace it when it goes out. That way you won't have to unbolt the whole thing. Just unplug it, twist it and it comes out.
Thanks for the information: I had no idea what it was locking/unlocking. Now the 'stupid' question: so in the normal mode it should be in the locked position?
