Hello. I just pulled my sunsifh out from storage. It was water logged. Found the ingress point, two cracks in teh cockpit. When attempting to drain boat we put a 1' crack in the hull. How would I go about fixing these? Form what I read I need to put out a certain area of the crack, and using carboard, mat and roving, insert them under the hull (no access from above). Than secure with wood and wire and allow to dry. Than level off with more resin. That seems straight forward, but how much will I need to cut out? Also, what can I do about replacing the gel coat? I have been considering replaceing all teh gel coat on the hull, but not sure about that.
