2004 Mercruiser 5.0 SN OW003759 with Bravo 3 SN OW108118.
Symptom: single beep every two minutes. Alarm goes away with key cycle, returns with planing speed.
Fault codes read on Rinda Marinetech:
75: smartcraft- NA
94: Pitot pressure sensor (used for boat speed) circuit open
104: smartcraft- NA
119: Steering sensor circuit open
130: Trim sensor circuit shorted
I have looked for cut and/or disconnected wire and can find none. All gauges and instruments work. How can I make this alarm go away? I assume if I choose the "erase alarm" option that it will just come back when I get on planing speed again.
OR.. other suggestions? Thanks.
75: smartcraft- NA
104: smartcraft- NA
