Re: EZ Loader Trailer
p sully,<br /><br />Brake fluid absorbs water. When it has water in it, it turns black.<br /><br />You need to get that stuff out of there.<br /><br />Here is how to bleed. You will need at least two other helpers.<br /><br />1. Block the trailer wheels, front and back.<br /><br />2. Hitch the trailer to the tow vehicle.<br /><br />3. Put the tow vehicle in reverse.<br /><br />4. Have some one crack open one of the brake bleeders. When the surge coupling has bottomed out in its rearward travel, close the bleeder.<br /><br />5. Put the tow vehicle in forward, have someone pour fresh fluid in the reservoir while the coupler is extending forward.<br /><br />6. Repeat, until you have fresh fluid coming out of both bleeders.<br /><br />Caution: be very gentle in the rearward and forward movements of the tow vehicle.
