Hi all,
I am new to boating and looking at getting a 12' Saturn SD365 with a 15hp engine. I understand that it will be difficult for the boat to get on plane when it is loaded.
I am thinking about making my own trim tabs but don't quite understand how they work. From what I gather one would generally want them to be at a slight down angle when getting on plane and then raise them up ones the boat is on plane. Is this the reason to use an actuator? Will the pressure on the trim tabs once the boat is on plane cause them to move up?
Is there a set angle that these should be set at when getting on plane? Will the angle matter afterwards?
Any input is appreciated
Cheers,
Mike
Cheers,
Mike
