HI,
A freind of mine has a Liberator with a 460 Ford. He has had trouble bringing this boat up on plane since he bought it this spring. He has changed props a couple times and that helped, but not cured the problem. He found that if he left the engine cover off, it helped improve his engine performance alot. Does this sound like the result of an exhaust leak to guys? He says it has a slight leak. Your input is appreciated.
Larry
Larry
