EVINRUDE
lovell
Is 153 hours exceeive for a boat engine? it is a 1972, 65 Hp pushing a 18' Tri-Hull mainly used for pleasure and fishing?
Dhadley
Re: EVINRUDE
The average yearly use in the US is 50 hours. So that is very very low. I'd be curious to find out why it was hardly used. With proper set up and care a two stroke outboard has a life of several thousand hours. Non use can sometimes be worse than heavy use. <br /><br />Good luck!
rickdb1boat
Re: EVINRUDE
That motor must have seen alot of storage time. Make sure all the wiring, lower unit and that compression is good. When they sit alot, it can be a problem. Otherwise, that is REAL good hours.
waterinthefuel
Re: EVINRUDE
How do you know it only has that much? Is is on an hourmeter as old as the engine, or did someone simply guess?
