I have a 1986 Evinrude 150hp motor that has started acting up. I have recently changed fuel line, plugs, had the carbs rebuilt and replaced all of the fuel. The engine starts fine at the dock, but after about 20 minutes of running it at 3500-4000 rpm, it loses almost all power and I can barely make it back to the dock at 1700 rpm. The engine will not idle either. Any help would be greatly appreciated. The service center that rebuilt the carbs said everything checked out as far as spark, etc, though they did not do an open water test. Thanks in advance. Scott Bonson
