got2bgreen45
- Jun 30, 2009
- 30
Put the boat in today and it starts and idles great. Also throttles up real niclely on the warm up lever. However, it dies unless you throw it into gear quickly, and with the control lever all the way forward (carbs are wide open at this point) the boat, along with the engine runs very slowly, and has trouble staying running. It dies when I try to go back to neutral. I am experiencing the same problem in reverse.
Also, it runs fine on the hose in my yard, and great in full throttle in forward and reverse. Why does it only have trouble in gear on the water?
For the first half of forward and reverse, the throttle does not increase, only through the second half to the full speed position.
Again, it throttles up fine when its not in gear. Im only having a problem in gear on the water.
What can I do to fix this?
1978 - 85hp Evinrude Outboard 85895C
I appreciate the help! Want to salvage whats let of today...
