I have an older Johnson 35 H.P. that runs pretty great right now. Had problems with it, but with the help from guys on this site, she is running pretty good currently. My question: The motor is a 1983 model. I have a can of this spray that is labeled as Evinrude engine tune-up. It says to spray it into the throat of the carb until the can is empty while engine is running pretty good on RPM's. Run the motor for about 10 minutes. Then let the thing sit for 8-15 hours. After that time, run the engine again at pretty good throttle for about 10 minutes and that will clean out the engine. I read the on line reviews on the product. The reviews are mixed, but mostly good reviews. The bad reviews were mostly saying the spray does not do too much and a waste of money. Since I already have the product and cannot return it, what is the general opinions here on if I should do it or not? Has anyone on here used this product or a similar one? Thank you!
EDIT: I currently use SeaFoam with every tank of gas.
