Unknown .. that's why they are called 'unforeseen'.....
What you will have to change is the exhaust elbows just above the y-pipe (not the manilfold elbows, the short, almost 90 degree tubes), and possibly gear ratio in the drive. Also the side engine mounts are too far back for the 350, you'll need new ones glassed in.
You should also let us know what year each engine is.... Some are more compatible than others...
Chris....
