Re: engine swap??
usglow, one important issue is also gear ratio.<br />V8s uses a 1:50 to 1 ratio, 4cylinders have a 1:80 to 1 and 1:92 to 1 ratio. You'll have to replace gears in upper outdrive to make it work.<br /><br />I had same problem with a drive I purchased to be installed in a V8, it was an Alpha from a 4cyls, I ended up selling drive and getting one for a V8.<br /><br />My 2 cents.....find another boat.
