Re: Engine mount
i'd call Bill or Scott up and see what they have to say.
i think i've ask this question before here on this forum. if i remember right, the answer is there is wood under the sole. that's what the lag bolts screws into. i know of no repair short of replacing the wood. which i doubt is much fun.
from memory, i've not seen anyone replace this wood here on this forum.
i would assume this motor mount wood rots just like other boats. from water intrusion. so suppose the foam is wet too.
keep us updated as to what ya gotta do. this would be one of the major don't wanna do things to happen to any boat i think.
hope someone has good news for you as to a repair. i'd really like to know what ya have to do too. i'm assuming that in the end, i'll need to know so i can repair mine too.
edit. did the lag bolt come out w/o screw threads. the few i've seen, when there's water intrusion to the point of ruining the wood, the lag bolt screw threads rust off. once the bolt is removed, ya can have a little better look at the wood from the top side... i know, pretty hard to see down that hole. maybe probe with a drill bit. see if ya pull mush out of the hole? if the screw threads are gone though. i'd think it's safe to assume rotted wood.
sure wish i had something nice to say. sorry...
oh, glad your engine ran super well this season. fwiw, mine did too... went out last weekend. high of 54*F. kinda chilly unless ya got a hardtop with aft curtain
. did me a wot run. got my 4300 just like i wanted... still running good i think...
