Re: engine keeps running after shut down contact
The 3.0L engines are very critical on the idle speed. If it is too high they will diesel (run backwards after shut down) this can also draw water back into the cylinders if it does it too long. <br />Another frequent cause is shutting down the engine immediatly after a long or hard run. Allow the engine to run at idle for a minute or two and if the idle is at the proper setting it should stop properly.
