got2bgreen45
- Jun 30, 2009
- 30
Today when we put the boat in, it started great (with the warm up lever up) but when I put it down to move the boat in gear it dies. The motor runs fine on the hose however. We have since figured out that the idle speed needs adjustment. It's a 1978 Evinrude 85 hp model 85895C.
Found a diagram of the upper carb (It has dual carbs) -
http://shop2.evinrude.com/cgi-bin/I...13\08.tif&ilSC=80&ilIV=0&ilBR=0&ilIF=P&ilRE=8
One other thing. On the carb I found a idle restriction plug, and an idle orifice screw. Would adjusting any of these help? I have already adjusted the throttle rod as far as it will go...
Any help is appreciated! Want to get the boat in for the 4th!
