Haut said:You need to get a digital volt meter & test the wiring, switch, & the motor itself.......
How far are you getting 12+volts in the circuit path?.....
I would test for 12v at the switch first....
Then you either backtrack or move on to the motor itself........
Welcome to iboats, btw......
Don said:If you can't do that, then you better have a fat wallet for the more complicated jobs.
