Electronic ignition conversion kit for Volvo AQ130C?
am_dew
I'm searching for an electronic conversion kit for my 1972 Volvo 4 cyl. 130hp AQ130C engine which has a Bosch part# 0231153012 distributor in it.<br /><br />Any leads would be appreciated. Thanks!
Manipulator
Re: Electronic ignition conversion kit for Volvo AQ130C?
Looks like the link you sent has the one you are looking for and its cheaper. Yeah, I would just call and check. I did find a sight that had FAQ on it. I will look for it. I was going to get one for my 5.7 OMC until I found out that it screws with your tach and also screws with the electronic shift assembly (ESA)or whatever its called. In my case you also had to build a fix (on your own)to fix the problem. So I said screw it. The whole point was for reliability and after having to make a thingy to fix some of the problems the electronic ignition posed, I then questioned the reliability. Points are cheap and I'm just going to boost the coil, widen the gap on the plugs and replace the points every season as opposed to every other.
