Hi, I am again working on another motor. With you guys help I have managed to get 2 running great for my family. Think we can make it three?<br /><br />I have a 1981 15hp evinrude model # E15RCIS Ser # E0005138, Tiller controled. <br /><br />It starts well and run well in a tub, but on the lake pushing a 14' Jon boat it bogs very badly at anything over 1/4 throttle.<br /><br />I read alot of post here and cleaned the carbs. Adjusted them according to the manual. I installed new spark plugs and checked the fuel pump pressure and lines. All seem to be fine. I am using the tank off my 28 hp that runs great so the tank/bulb/hoses are fine ( it is mixed 50:1).<br /><br />I then checked the compression, it reads pretty close to 100 100 when cold or hot. I also inspected the plugs after my last venture on the lake and they seemed to be oily and wet like they were not burning well.<br /><br />My next step was electrical area. I visually checked the wiring and connection, The only problem I have run into is some splices here and there, they seem to be sound and not loose. I have checked the ignition coils resistance, they are within the specs listed in manual. <br /><br />I attempted to check the power pack and the motor did not seem to match up to the books test procedures, and I am not sure if I even have a sensor coil as I dont know what it is. I assume since the motor is maual start it does not have a charge coil but every time I assume anything I am wrong so who knows.<br /><br />Aside from the power pack test and the sensor coil thing I have about tested everything I can think of, and I would really like to know what is wrong before I go buying things I do not need. So any help or things I should look for would be great. <br /><br />I know this is long but I wanted to let you know what I have done exacly and what I have found.<br /><br />Oh one last thing I forgot to mention, I rebuild the water pump on it before I even tested it on the lake, and it is working well. The engine never really gets so hot I cannot touch it for 10 seconds or more.
