Backcountry
- Mar 30, 2008
- 27
Trying to install a 320c in the bow, but before doing so, figured I'd test the unit as it is used. Wired to a 12v source, and will not power up. Don't think I would have fried the unit by doing this without an inline fuse, but not sure. If I did, I'll feel like an idiot.
Anyway, pulled the plug out of the back of the unit to see if I could measure the voltage in the cable with a multimeter. Don't get any voltage reading from any of the female connectors on the plug. I do see a little rust/corrosion on a couple of them. Could it be a bad power/transducer cable? I should have seen some voltage reading if it was working properly, right? There are 6 connectors on the cable and 6 pins on the unit.
Any thoughts? Thanks.
BC
BC
