Re: Drain plug on fletcher arrow missing ?
If the drain hole is threaded internally, odds are that it's a standard pipe thread. A normal expansion plug won't work.<br /><br />However, you can buy a PVC threaded pipe plug at any hardware store that is the right size, and use that to check the threads. You won't damage anything if it doesn't match. Actually, you can go ahead and use the PVC plug, but I'm guessing that the original was not plastic.
