I am servicing my older Sea Ray AJ that has closed cooled V8s. Salt water goes through the heat exchanger and risers only, not exhaust or intake manifolds. Intake manifolds are aluminum and stat housing is copper. All hose fittings inserted into iron manifolds are bronze. Motors have green antifreeze. I noticed green ooze or almost crystilized green stuff around the base of the stat housings where they are bolted onto the aluminum intake. I suspect dissimilar metals is causing this mess and there really isn't anything that I can do? Or, should I replace the green antifreeze with something else?
Thx!
Thx!
