The older fella brings in his daughter's little pink and white SeaRay jet boat.
"I think there's water in the gas... it won't run right anymore."
I open the engine bay and upon inspection I didn't find water in the gas but I did find this...
:facepalm:
and that is????
Apparently the motor was still running after the hit.
The transom and the hull are intact.
The two trim/tilt cylinders were the only thing holding the lower to the boat...
The boat will be back in the water tomorrow.
Sorry... I kind of forgot the non mechanic guys.
look at the connections on the battery.
red cable = +, take a closer look...
Huh, I just killed the 90 Amp fuse on my starter, and my stereo's fuse when I did that. The lesson I learned is that you don't change a battery at the ramp when you have a boat full of bikini-clad coeds waiting on you to change the battery. End result was no bikinis on the boat that day.
