Yep, read thru some of the other resto's posted in the Resto forum. There is a fair amount of work ahead. Pulling the engine, and making sure the hull is well supported on more then 'just' the trailer bunks/rollers are the 1st steps. There are many more to come.
Making sure the hull doesn't deform after you start gutting it, and moving around inside the hull while doing that, is IMPORTANT.
NO Pressure Treated (PT) lumber or plywood, unless it's kiln dried PT, which is not easy to find in many locations. Being in Florida, you may have a much better chance of finding it then I do in WV. The stuff from HD or Lowes isn't a good choice for many reasons, which are discussed at length in many of the Resto topics.
Welcome to iboats
