Went to the lake today put the boat in the water, when i was cranking my boat it would turn over and then just stopped. Wouldn't do anything. By the way I charged my batteries yesterday and the battery charger showed full charge. Couldn't even get the tilt to work so I thought it was the battery. Switched the battery to one of my trolling motor batteries. Same thing, would start cranking then stop. The battery gauge showed it still had a good charge on it but it was working. When i cranked it at home on a trailer, all went well. Even when I tried cranking it would just run the battery down and you could tell, but this time in the water it would just stop and not slow down if that makes sense. I am a newbie to boating but some experience with motors. Two things that came to mind for me was it lost ground or there is a naked wire somewhere. Also I recently added an onboard battery charger and this problem did not occur till after the installation. Thanks for your help
