Hello!
I recently came into the ability to pick up a shore station boat lift for super cheap (few hundred) and am curious about the ability to use it for my pontoon boat. I have a 20' pontoon as you can see in the photo attached to this message. I also attached 3 different photos of the lift showing more detail about it. My question is... Can I convert this V lift for a speed/fishing boat over to work with my pontoon? I do not know the exact model of the lift unfortunately, I'm working on finding that information but I do know that the lift is 9' wide "internally" inside the posts as well as 9' long inside the posts as well (a square) and my pontoon is 8' wide. That's a little tight but I'm thinking that if this would work that it might still be fine.
My questions are...
1.) Do you think I could convert this lift to a pontoon lift in a way that I'm not spending $1300 on the pontoon conversion bunks from ShoreStation directly? It's a great design, but for $1300, that seems extreme. Plus, I'm not even sure this lift would be big enough for it to work.
2.) If it would work, do I even need to have bunks for it to work with my pontoon? Or could I simply take some of the bunk fabric and wrap it around the cross members and just rest the pontoons on that and call it a day? Or, I attached a photo that shows where the hull of the speedboat would rest or be caught with a rubber flex piece, could I simply attach that across the entire cross member and go that route?
I know that there is another option to where I could buy from ShoreStation two bunk converters that would basically allow me to lift the boat up under the deck like those scissor lifts do, but the conversion cost for the raisers for that route cost about $400 and then I'd have to buy the wood, wrap it and at that point in time, I'm still unsure it would work to begin with.
My ideal solution would be to simply buy some felt and wrap the cross member and just rest the pontoon on the steel/aluminum and remove the v hull bunks altogether and just call it a day, but with it not being a straight bar and more of a U shape, would that cause a problem?
I'm not even sure the lift would work to begin with, so I'm leery to invest money into it.
Thoughts?
Thanks,
Mike
My questions are...
Thoughts?
Thanks,
Mike
