Need to / want to do a compression test and am getting too much arm chair opinions. Got a 99 Ficht 150, no problems really- but will be decarbing, and changing plugs- so why not see whats it at? All advice has been from non boat owners- so what better place to ask....<br />Gotta do it in the driveway- manual says all 6 plugs out- and gage. Some have told me to do it at WOT, I'm assuning via in WOT idle, does it have to be WOT idle. Can you push it to WOT and turn it over? Is this correct? Or couldent you just pull the 6 wires off, and do cylinder at a time, putting in the new plug when that cylinder is done? Or would that build up too much pressure in the 'plugged' cylinders, and be hard to crank.<br />Most I've tested were single plug lawnmowers.
