Cobalt Weight
manykids
I am going to look at a 1985 Cobalt tomorrow. Does anyone know approximately how much boat / trailer weigh? It is 21', 260 HP w/ tandem trailer.<br /><br />Second question, can one be pulled w/ a mini-van equiped with a tow package? I have a 2000 Montana. The bar is rated for 3,500 lbs and the instruction manual says I can tow that much for a short distance. Anyones thoughts here? :confused:
tommays
Re: Cobalt Weight
i have a venture and dont think it would be up to the job<br /><br />i dont no what it weights but my but my 1995 Maxum 19 ft with a 3.0 is 3850 with the trailer <br /><br />MY Silverado with a 4.3 has a 5000# RATEING and the boat and my stuff uses it all UP <br /><br />every boat i have looked at in the 21' and up size range is to heavy with out going to new truck with a V-8<br /><br />tommays
roscoe
Re: Cobalt Weight
3600# plus trailer, gas, gear, coolers, and the weight of anything and anyone in the tow vehicle.<br /><br />The answer is clearly NO, your vehicle is not up to the task.
manykids
Re: Cobalt Weight
An update. The 22' was trashed on the inside, so I ended up with a '79, 18' Cobalt. Now for the same question, can the van handle it for a short run to the lake...never over 50 m.p.h.? The trailer has brakes.
alden135
Re: Cobalt Weight
Go to the link I posted and look it up with the new info.
manykids
Re: Cobalt Weight
According to NADA, the boat is about 2,700#. Any educated guess on what a tandem axel Shorelandr trailer weights? It is an '86 and can be stretched to accomodate a larger boat.
craze1cars
Re: Cobalt Weight
If you've already bought the boat, take it (carefully and slowly...or with a stronger tow vehicle) over to the nearest truck stop that has a scale and weigh the whole mess at once and get a true answer. Your life, and everyone else's life that you drive past, is dependent on you getting an accurate answer to this question. It's worth the $10 fee.<br /><br />If NADA says 2,700, I'd guess the boat is closer to 3,200 to 3,500 with gear, fuel, fluids, waterlogged stringers/foam/transom, etc. Plus trailer....a tandem weighs in probably 800 to 1,000? And be aware that your tow rating is based on a vehicle plus driver, and no luggage. So add another 800 lbs for your overweight friends and 2 coolers of beer you're hauling in the van. Where are we now, somewhere between 4,200 and 5,000 maybe?<br /><br />No matter how we dissect this, methinks you're overweight and you need a different tow vehicle. But no matter what numbers anyone throws around here, the only thing we know for sure is that we're all just guessing.
