Re: Changing fuel lines and tanks
Jetman - I have the same engine - '57 Johnson Javelin (ok almost the same engine). I had to find the tank, the hose, the fitting, the gastkets, and paint the tank (just did that today at lunch). Ended up costing me about $80. You can find the entire package on Ebay, they usually, in decent shape, go for about $50-$60. As far as changing over to a single system, I don't think so. The compression line for the tank is there for a reason. I don't even think you could install a fuel pump on the tank and force the gas in. The engine knows how much gas it needs, that's what the air flow is for. Let us know how it turns out!!
