Re: cav plate height /effect on trim
Theoretically the cavitation plate should be flush, & paralell, with the bottom of the boat as a starting point. If you find it works for you a bit higher, that is even better, less lower unit (drag) in the water, unless you have it so high, there's a problem with picking up enough water for your water pump, then lower it down just enough to remedy that. Tilting the motor up some while under way, raises the bow, and takes more boat out of the water, makes it faster, just before it cavitates (because this will cause prop slippage, and it's not good) lowering the tilt to much while underway, will cause the bow to drop, excess will causing plowing, (also not good).
