carb redo
fishman204
Just got done rebuilding the carb on my 96 225 ocean runner.The only thing found in carbs was in the long tube that goes to the bottom of the bowl was clogged in one carb.Is this the idle input?? Also on the aluminium butterfly section the idle air mixture gaskets looked horrible they are sandwiched by the cover plate would this affect idle? cause before she was idling,coughing.These old gaskets had cracks in them.Took a few hours to do all six with cleaning everything, all bak together now
boobie
Re: carb redo
The things you found will cause a bad idle. How's it run now ??
fishman204
Re: carb redo
It may be afew weeks till some other things get done.The small diameter bolts in the front of the base gasket are broke too.Does anybody know the size of these
