Hello again, 1973 merc 200 20 hp<br /><br /> Just rebuilt carb and changed out foam float to a plastic float. Started up motor but she is still coughing at idle. Adjusted idle mix 2 turns out and fiddled with it but no major difference.<br /><br /> At idle she coughing then spits then shuts down. I squirted gas-oil mix into carb throat while at idle and she runs smoothe as long as I keep spraying her.<br /><br /> Is this a problem with float adjustment? which way do I adjust float to feed more gas at idle??? Thanks again for help
