Re: cam position force 125 1988
"It is NOT a running position since carbs must be cracked open slightly and timing advanced a degree or two at idle."
This statement by Frank is very important especially in your case. It means if your engine is already capable of starting and idling, the cam's two lines should not align with the eccentric screw slot anymore because you now have the throttles slightly open and timing slightly advanced. When the cam's two lines and eccentric screw are aligned (initial settings, meaning you have zero idle screw setting), unless control handle is in fast idle, the engine should not start nor idle because the throttles are fully closed. In short, from the initial setting of zero idle the cams and eccentric screw should align and then set the idle settings (800~1000 RPM on muffs) which advances the cam and timing thus the the cams and eccentric screw do not align anymore, normally.
