Bravos vs Alphas
tank1949
I am interested in purchasing a boat that has twin Bravo drives. The boat has been retrofitted from Alphas. I am somewhat familiar with Bravos but not an expert. Are they superior to alpha drives? What is the drawback?
Ayuh,.... Heavier, Heavier duty, 'n a cone-clutch, far Better than an Alpha,....
thumpar
The cone clutch in the Bravo is what I like most. The shifting is smooth. I went from a boat with an Alpha to one with a Bravo and love it.
mr300z87
Had a boat with an Alpha, current boat has a Bravo, Don't think I would ever want to go back. Bravo is far superior.
tank1949
383 Stroker and Bravo drives
I am interested in a boat that has been retro'ed with Mercruiser Bravos and 383 Strokers from Alpha and 350 Chevy blocks. Motors have Rochester 4 barrels and manual fuel pumps. I suspect if propped and trimmed correctly, these should max out at 4200-4400 range like there 350 Chevy counter parts. Owner stated that they burn regular gas, so no high compression heads. Does this RPM range sound right???
thumpar
It actually sounds a little low. I would try to shoot for 4600 or maybe a tad more. Are you able to talk with the engine builder?
Ayuh,...... SBCs with 2bbl carbs are usually proped as low as ya say,....
SBCs with 4bbl. carbs are usually proped to 4400/ 4800 rpms at Wot,....
I always shoot for 4800 rpms,....
'n lets keep all yer questions 'bout this in one topic, not many topics,.....
tank1949
So were are looing at about 400 more RPM? THX!
