n6xb
- Aug 23, 2011
- 18
My 1994 Bravo III outdrive has been getting harder and harder to shift. Finally, when we tried to use the boat one day, it was impossible to move the shift handle.
After a little trouble-shooting I found that by removing the back cover on the outdrive #2 below, and then removing the spring and ball #4 and #15 below, the outdrive shifted perfectly! Although shifting was a little sloppy and finding neutral was a little critical. Other than that, shifting was restored to normal. I noticed that the shift arm #14 had quite a bit of rust on it. I cleaned the exposed surface where it detents with the ball and put it all back together, but that didnt seem to make any difference. The rest of the outdrive components under the back cover looked very clean with no corrosion.
I am thinking maybe the rusted shift arm needs to be replaced. What is the procedure for replacing the shift arm? Does the outdrive have to be removed for this procedure?
Any other ideas or comments would be appreciated!
Thank you!
Thank you!
