CayugaCobalt
- May 6, 2008
- 89
I have installed a new bearing carrier because my 1997 Bravo3 outdrive was leaking drive oil thru the heavily corroded original bearing carrier.
I thought I found the capacity for my Bravo 3 OK180251 was 3.5 qts. I was only able to put 1.75qts in lower drive before it came out vent hole, which is half of 3.5 I was expecting to use. Then I plugged the vent and continued until I accidentally overfilled the monitor bottle ( just a little) but in total only used 2.5 qts.
I did lower the unit back down and rotated shaft both ways a little bit hoping it might drop as it is still a little over full in the monitor bottle.
Is the capacity 3.5 qts or 2.5 qts?
Thanks for your feedback.
