jimmy239482349
- Apr 8, 2024
- 26
Model number: BE60TLEUA
Video demo: https://streamable.com/2a1fkn
As video shows. When I take off the carb linkage and throttle each carburettor individually the bottom cylinder sounds groggy in comparison.
- 110 compression on all cylinders
- Replaced stator
- Made sure fuel supply is good
- Carb freshly cleaned and assembled properly
- Have tried switching Coils
- New stator
- New voltage regulator
- New spark plug leads
- Apparently new cdi
- New and correct spark plugs according to cdi spec
- DVA tested the CDI all getting ~200v+ to each coil
- Tried adjusting air fuel screw on the carb
- Tried switching carbs and problem maintains on bottom cylinder
Appreciate any help thanks
- Replaced stator
- New stator
