Re: Boat seems to lean to side - on plane
Probably wouldn't hurt to center the trim tab ("rudder"), but that is probably not the cause of your problem in the first place.<br /><br />You should probably try to lift the bow as far as it goes by trimming the drive out as far as to make the boat porpoise, then in some. And, as several folks have advised, add trim tabs; any kind of tabs will serve but you seem like you'd appreciate the ease of use of the Smart Tabs. Make sure your balance out the load on board if you can. Good luck to you.
