godspede619
- Aug 26, 2008
- 54
Working on a repair today and ran into a little issue. The damage area is a crack on one of the speed strakes that was about 2in long. Prepped everything good..12:1 bevel, glass is cut to size. I am using both a 1.5 oz mat and biaxle cloth with a poly resin. Mat went on perfect for the first couple layers but ran into a problem with the biaxle.. Because the repair is on the strake and not on a flat surface, i had trouble getting the biaxle to conform to the hull. Was getting air bubbles that i could not get out.
My question is.. can i cut the biaxle patch in half and appy the two pieces separate so i can avoid making the turn over the speed stake? Then apply mat over the peak of the stake to make up for the 1/4 in loss? I will gelcoat everything when finished. Should I be using a different product...? Thanks guys..
