I have read through a bunch of posts and seen some of you can do wonders in regards to best prop size/pitch with a little bit of info.
I was wondering if you could tell me which prop would be the best for my boat with the main usage will be kneeboarding/wakeboarding/tubing and possibly barefooting.
Current set-up Info:
The boat is new to me and the local lakes are a little stiff right now so I do not know WOT RPM and speed. If you require this let me know and I will get back to you in the spring!
Prop mfr is unknown to me, 3 blade aluminum.
14.5 X 19 pitch
Average load approx. 600lbs plus 25 gallons fuel
2007, Volvo Penta 5.0GL-H, 220 HP, SX-A Drive with 1.79 Ratio
2007 Blue Water Cascade 20'3" & 2650lbs
Thanks!
14.5 X 19 pitch
Thanks!
