Some of you will hate me for what I am about to tell you. That's OK and I under stand.
After reading a number of post on wheel bearings problems I feel it is my duty to explain a few thing you are not aware of.
BB's (Bearing Buddies and others like them) seamed like a good idea at the time. Turns out that they are non effective and in general lead to more problems than they are worth. I liken them to a "Chrome Plated Boob Job" , They may look good, but fail to provide any enhanced function. Same thing is true with breast implants "They look good but fail to feed the baby'. And of course there is an added risk for the kid. The fact is You are better off with the original design Dust cap and annual repack.
Many of you know that BB's Leak grease out because of the vent hole, miss use and blown seals. If they leak grease out, then they will leak water in!
Even more serious is the decreased diameter of the retention washer of the outer bearing (allows grease to be forced around and through to the inter bearing). Should the outer bearing fail, The wheel will come OFF!
About this time you are asking "why are they on all trailers?"
It is because you asked for them and because of a sales campaign.
Dellori3
Dellori3
