5.0L Mercruiser 2006 Alpha gen 2 drive.
Recently replaced IAC.
Boat had broken bow line at a dock and was blown into the dock repeatedly with the drive hitting the dock. Did the drive get knocked out of alignment? We were able to get home fine after that incident. It was about 30 minutes down river.
We set out today to the beach and as I began to give the boat throttle it responded up to a certain point and then it seemed like the propulsion stopped but the engine kept revving and reved higher when the propulsion stopped. 2 things I’m thinking of: bad engine coupler or the hub in the prop is spun. I think I am going to borrow a prop from a friend and see if the boat responds the same way. We were able to get back to the dock under power and propulsion. Under low load it putted around fine, it was only when I gave it some load that it dropped out.
One person was of the mind that if the engine coupler failed that there would be no transmission to the drive.
Any trouble shooting ideas would be appreciated.
