Re: Anyone know what type boat this is?
It's not a wood frame. The gunnel is glass(rather dry glass) over what appears to be PVC pipe. The bow portion may have been glassed over foam. There are several small pieces still there(the light brown stuff in the picture).
Interesting, thanks for the explanation.
There are no soft spots that would suggest a wood bottom.
I wouldn't expect to find soft spots unless there was some rot going on. I don't see any blistering in your pictures that would make me suspect water intrusion. Of course, you have a much better view.
The forward and aft compartments were made using preformed fiberglass pieces and installed after the hull was fabricated.
There is some logic to making and installing the lockers separately.
I don't know if the bilge is hallow or not. The clean out section in the photo is the only section exposed or accessible. The forward and aft sections are connected with a 1'' brass tube. I would say that the photo shows a bailer drain.
The raised deck seems unconventional, just in that it places crew and gear weight a little higher than more traditional board work would.
If the area is filled with foam flotation, no doubt the boat would stay afloat if swamped, but given the buoyancy distribution I suspect it would be upside down.
It strikes me the fore and aft lockers alone have enough volume to buoy up the boat provided they are kept sealed shut while under way.
Forward sail, oar locks, sealed cockpit floor, a large bailer with clean out sink, and fore & aft wells/lockers with drains. I'm beginning to wonder if this was some sort of small scale fishing boat.
Despite being fiberglass, this would be a good one to run by the old-timers at Wooden Boat Forum.
