Mariner60_hp
- Mar 26, 2003
- 26
I installed a Teleflex Tach on My 1980 Mariner 60hp (Model 60EL , Sn 675L305318 outboard, actually commonly known as a Japanese Mariner built by Yamaha). The destructions that came with it said it would work ona Mariner 18, 25, 48, 60 HP through 1983. and gave the settings. I hooked it up and it works (well kinda). The idle seem correct,the voltage at 2000 rpms seems correct but it max's out at 4000 rpms. Now I know the motor is turning more than that(so now I read the fine print)> It says that : some 30 & 40 HP 2 cylinder motors non-USA built motors(which mine falls into 2 of the 3 catogories) may require a module ( Mercury P/N 17461A2) when using any of these tachs. Anyone in the world know how to make this tach work correctly. Have already tested rectifier, it tested good and Teleflex has yet to respond to my email. I NEED SOME SERIOUS HELP PLEEEEEEEASE.
