Re: anchor light??
@ Chriscraft:
I don't understand. In your last sentence you state that the bow light should not be on while anchored. If the lighting is configured with 180 degree light on the bow and another 180 degree light on the stern how can you have a 360 degree anchor light if your switch of the bow light?? Am I missing something?
Read what I wrote again. I said if you have "two" 180 degree "white lights".
Some larger vessels I have seen will have a stern white light and another 180 degree white light mounted forward of the cabin, usually up high. Usually wired so when running lights are switched to anchor lights, the bow running lights go off and the second 180 degree white light lights up with the other 180 degree white light to give you 360 degrees.
In other words, one 180 degree white light forward and the other white light shining towards the stern.
Have not seen many set-up this way, and really don't like the set-up. I have only seen this on open cruisers with no hard top structure to enable a good 360 degree all around light..
